Did the thread subject catch your eye? Well, if not, here are some pics that should and I hope to see everyone posting pics of their setups. Following is my secondary ADAM setup and I will get around to taking pics of my main setup asap. The configuration of this ADAM setup is as follow:
- Bay #1: Digital Data Drive
- Bay #2: Internal FujiNet by Lundy Electronics
- Internal Slot #1: IDE Interface with Dual CF Card Adapter by MicroFox Technologies
- Internal Slot #2: Addressor Card by MicroFox Technologies
- Internal Slot #3: 512K Memory Expander by MicroFox Technologies
- External Expansion Bus: I/O Expansion Hub (3 in 1) by Lundy Electronics
- External Expansion Bus: ADAM Speech Synthesizer by Lundy Electronics
- External Expansion Bus: ADAM Sound Enhancer by Mozzwald
- Controller Port #1: USB Mouse/Joystick Adapter by Lundy Electronics
- Controller Port #1: A500 USB Mouse and Coleco Hand Controller
- Power Supply: Ultimate External Power Supply by Lundy Electronics
- LCD TV spray painted to match the ADAM
- Printer: Panasonic KX-P1080i connected to my main ADAM system
- Printer: ADAM Printer (not connected)
- Numerous additional hardware items and accessories in cabinet not being used currently
- HP Windows 7 Laptop for FujiNet web configuration and 80 column terminal setup on main ADAM system
You show me yours and I'll show you mine... ADAM that is!
Re: You show me yours and I'll show you mine... ADAM that is!
Here is my main ADAM Computer which is heavily modded and enhanced by Lundy Electronics... referred to as a Super ADAM.
- Bay #1: SD-DDP by Lundy Electronics
- Bay #2: Internal ADE Pro by Lundy Electronics
- Internal Slot #1: empty but I do have an extra IDE Interface that could fill this void
- Internal Slot #2: MIB238 by Lundy Electronics
- Internal Slot #3: 256K Memory Expander by Micro Innovations
- External Expansion Bus: Super Game Module by Opcode Games
- Controller Port #1: Coleco Hand Controller
- Controller Port #2: Coleco Hand Controller Mod by Yurkie
- Power Supply: Internal Power Supply by Lundy Electronics (part of the Super ADAM Mod)
- Comm Panel installed on back of unit with 1 Parallel and 2 Serial external ports
- Modem: WiModem 232 (Serial WiFi)
- 5 1/4" 160K Floppy Disk Drive
- HP Windows 7 Laptop for 80 column terminal setup via the MIB238
- Attachments
- image0.jpeg (905.36 KiB) Viewed 51172 times
- joltguy
- Has thanked: 5 times
- Been thanked: 4 times
- Contact:
Not my current setup (which is sadly messy at the moment) but I had this setup for a while.
