New ColecoVision & ADAM Emulator Released: ADAM+ (Open-Source)
User avatar
RGDiRocco
Has thanked: 15 times
Been thanked: 29 times
Post by RGDiRocco »
Screenshot 2025-12-05 202015.png (965.57 KiB) Viewed 24298 times
r/emulation - New ColecoVision & ADAM Emulator Released: ADAM+ (Open-Source)
Hey everyone!
I wanted to share something We’ve been working on that might interest the retro crowd here. We’ve just released ADAM+, a brand-new open-source emulator for the ColecoVision and Coleco ADAM systems.
👉 GitHub page (downloads, info, source):
https://github.com/dvdh1961/ADAMP
What makes ADAM+ interesting?
Runs ColecoVision ROMs and ADAM disk/tape images
Supports Super Game Module features (AY sound, bankswitching, etc.)
Built-in debugging tools: tile/sprite viewers, VRAM/RAM inspection, disassembly
Pixel-sharp video mode, EPX interpolation, bezel support
Save/load states
Available for Windows and Linux (x86-64)
100% open-source (GPL-3.0), built with Qt6
We created this project not just for playing games but also for exploring how the ColecoVision and ADAM work internally, and to give homebrew developers a helpful modern toolkit.
If you check it out, I’d love to hear:
Which games work well for you
Any bugs or quirks you spot
Feature ideas or improvements
Homebrew experiments!
Thanks for reading — hope some of you enjoy trying it out!
User avatar
RGDiRocco
🎉 ADAM+ Emulator — Version 0.3.11.25 Released! (Windows & Linux) (Open source)
Post by RGDiRocco »
Hi everyone!
We’ve just released a new update of our ADAM+ emulator, and it comes with several improvements, fixes, and quality-of-life updates. Here’s what’s new:
https://github.com/dvdh1961/ADAMP/relea ... /0.3.11.25
📝 Changelog — v0.3.11.25
🔒 License Update
Switched to PolyForm Noncommercial License 1.0.0 (some parts of the project required a license change for compliance reasons)
🕹️ Input Improvements
Added USB joystick support
🖥️ UI & Usability Enhancements
Added support for resizing the application window to any format
Added toggle for bezels on/off
Added toggle for snap windows on/off
Added saving of window geometry, so your layout persists
💾 File & Installation Fixes
Changed Windows installation path (no longer under Program Files)
Media map is now standardized to the working directory, fixing save-related permission issues
We’re continuously improving the emulator, and user feedback has been incredibly helpful so far.
If you encounter any issues or have feature suggestions, please let us know — preferably by opening an issue on GitHub so we don’t miss anything!
Thanks for supporting the project, and enjoy the new update! 🙌
User avatar
RGDiRocco
Re: New ColecoVision & ADAM Emulator Released: ADAM+ (Open-Source)
Post by RGDiRocco »
To approximate the behavior of the original Coleco Adam as closely as possible, we have modified the method for handling ROMs, Tapes, and Disks using the buttons that are also present on the original hardware.
Screenshot 2025-12-05 202349.png (320.39 KiB) Viewed 24297 times
The revised workflow is as follows: Media Load & Run: Load the desired media (ROM, Tape, or Disk) and subsequently press the corresponding RESET button to initiate the media:
Use the 'CARTRIDGE RESET' button to start ColecoVision ROMs.
Use the 'COMPUTER RESET' button to start Adam-specific media (Tapes and Disks).
Full Media Unload:
To fully release or unload all currently mounted media (ROMs/Tapes/Disks), press the 'POWER' button.
We have implemented a paddle function. If a joystick has been selected, the user can verify the functionality of their analog stick using the small keypad widget. To play a game requiring a paddle, the user must select the paddle mode in the menubar. When activated, the left and right cursor keys are replaced by the left/right axis input from the analog stick.
